Softpress
Importing Flash files in Freeway
Embedding a Flash animation (SWF) into a page in Freeway is very simple. Just draw an HTML item and either drag the SWF from a Finder window or go to File > Import. The Inspector palette will change to show that you have a Flash file selected and using the third pane of the palette (Output settings) you can choose how the Flash animation should be handled. There are options to loop the movie, autoplay and whether you want to use the Eolas workaround that stops visitors using Windows IE having to Ok a dialog when the page loads.
To embed a Flash video file (FLV), you will need to use the FLV Player action, as they work a bit differently than the SWF files do. You can access the FLV Player action by selecting Insert > Action Item > FLV Player, or by clicking Actions on the Tool panel and selecting it from there. You can then choose settings for the video in the Actions palette.
Related Articles
No attachments were found.
Article Details
Last Updated
1st of May, 2009
Would you like to...
Print this page  Print this page
Email this page  Email this page
Post a comment  Post a comment
 Subscribe me
Subscribe me  Add to favorites
Remove Highlighting Remove Highlighting
Edit this Article
Quick Edit
Export to PDF
User Opinions
85% thumbs up 14% thumbs down (7 votes)
How would you rate this answer?
Thank you for rating this answer.
Continue
